QTI Line Sensor Power
I have more experience with software than hardware, you might say I'm not grounded in electronics very well (haha ...). I was wondering if it would be possible to power several QTI Line Sensors with one I/O Pin - my problem is that I need separate readings for several sensors, but I can take them all at the same time. That way, instead of having 6 sensors using 12 I/O pins, I would be using somewhere between 7 I/O pins and 9 I/O pins. I don't know how much of a problem Fan-Out would be though ... any suggestions welcome, I just don't want to fry anything.
I'll have a pretty cool project to post when I'm finished, which for better or worse, has to be this weekend
Jon Williams
Dallas, TX· USA
·· I would take Jon's advice.· That is not a typical configuration for an NPN transistor, and in fact, you don't want to connect the base directly to the I/O pin without a resistor·of at least 220 ohms.· Besides that, an NPN transistor, to put into laymans terms/simple terms, is meant to switch the negative side.· that is the Emitter is connected to ground, and the Collector between the device and Vdd.· A PNP transistor might be more appropriate to drive a positive load, however that would require a low on the Stamp pin, and you'd still need the resistor.
·· In any event, trying to simplify this is getting past the point.· Take Jon's advice and use an I/O expander.· there's plenty of code available for using them.
csavage@parallax.com
