count function on Bs2p — Parallax Forums
divsterdivster Posts: 2
edited 2005-04-05 17:51 in BASIC Stamp
I am trying to measure frequency using the COUNT function in PBASIC. For the project I am working on, I need to get as high a count as i can get....but am unfortunately limited by the WORD size - 65535 max limit.
Is there anyway I can count to a higher number?
    edited 2005-04-04 22:51
    No. What you can do, though, is count for a shorter period.
    Jon Williams
    Dallas, TX· USA
  • divsterdivster Posts: 2
    edited 2005-04-05 05:02
    Counting for a shorter period doesn't give us enough resolution - for the sensor we are building.
    Would ideally like to count to a million over 1 second - but anything over 65K would be a good start.
    Is there any kind of flag or interrupt that overflows when the counter rolls over? Is there any such thing we can use to increase the counts?
    edited 2005-04-05 12:14
    No. The BASIC Stamp may not be the best solution for your application. You might consider an SX microcontroller -- we now provide a free BASIC compiler with our SX-Key tool kit; perhaps that's a viable option. That said, SX/B does not have the count function of PBASIC, so you'd have to code that yourself. Doing so would allow you to create and use a 24-bit variable (in assembly).
    Jon Williams
    Dallas, TX· USA
    Another limitation of the COUNT command is that the highest frequency the BS2p can count is around 400khz, so your goal of 1 million per second is not possible from that standpoint either. Maybe you could use an external prescaler to reduce the frequency to a range that the Stamp can COUNT, say a /10 to reduce 1mhz to 100khz? Yes, that would degrade the resolution. But the Stamp's COUNT command depends for its accuracy and stability on a ceramic resonator, which will be important if you are really going after 16 bit precision.
    Tracy Allen
    www.emesystems.com
