JST Connector
Hello,
I am using a JST Connector to connect a Sharp GP2D02 to a BSII.· The connector I received from HobbyEngineering.com has the following color wires:· White, Blue, Red and Black.· Other JST connectors I've seen use Green, Yellow, Red and Black.· Does anyone know how the White, Blue, Red, Black scheme translates to the GYRB?·
Any help would be appreciated, since I think this is the reason why I can't the IR to work.
Stan
Stan
A JST (Japanese Solderless Terminal) is a mini connector that allows the Sharp GP2D02 to connect from the IR Sensor to the breadboard.· The connector has a 4 pin head which are crimped onto white,red,black and blue wires.· The head goes into the Sensor the wires inserted into breadboard.
Stan
It matters more what the order of the pins are than the colors, I believe, but it would be nice if you knew what the mapping really was.
