continuity tester on Stamp?
Hello. I'm planning on using a Stamp controlled transistor to send current to an electrical match. The match blows at about 0.5 amps. Is there anyway I could have the Stamp make sure the e-match is still intact?
Matthew
Matthew
·· Sure!· One simple way is to (assuming you're using an NPN transistor) connect a stamp I/O pin to the collector, and use a pulldown resistor of around 10K (You may have to adjust this).· When the stamp I/O pin reads high, the e-match is still intact.· Of course, you will have to test it while it's not active (Between turning it on).
·· This is similar to how my headlight circuit worked on my computer car (RIP).· This assumes the e-match is connected directly to the collector and the other end to positive voltage.· Once the e-match is blown, you'll read low all the time.
csavage@parallax.com
I'm seeing ground and a 10k resistor being connected the collector, with the resistor going to an I/O pin. Am I wrong or right?
Matthew
·· No, I have to make some assumptions here due to lack of details about transistor type, voltage, etc.· Assuming a 2N3904 (Just within tolerance of the current) and a 5V high voltage:
·· The Stamp pin for control would go through a 220 Ohm to 1K resistor into the base of the transistor.· That's one connection.· The transistor's Emitter will go to ground.· That's the second connection.· Now, from the collector you are presumably going into this e-match, and the other lead of the e-match to 5V.
·· From the collector you will also have another line going to an second pin on the Stamp (INPUT) and also tied to ground.· It doesn't matter if the pull-down resistor is at the Stamp pin or the Transistor's collector.· Electrically it's the same.· But the resistor goes to ground from there.
·· This keeps the Stamp's INPUT pin from floating when the e-match is blown.· You should only see a HIGH on the INPUT pin when the OUTPUT pin is LOW, and the e-match is good.· Otherwise you will see a LOW.· If you see a LOW, and the OUTPUT is LOW, your e-match is burnt, toast, history, the blue smoke has come out...·
·· I was thinking about what I said, and I built my original test circuit.· The only thing I had to change, which I remembered afterward was the pull-down resistor.· I switched from 10K to 100K due to minimal current draw across my load, which, being a bulb wasn't wanted.· IOW, a 100K resistor will also work, and may be a better solution for you.
http://focus.ti.com/lit/ds/slis010a/slis010a.pdf
try a TPIC6595N in your circuit to maximize your number of outputs
" Hey! Why is there silicone on my hemostats?"
Post Edited (nick bernard) : 4/5/2005 9:11:24 PM GMT
Check the model rocketry sites and you'll find them.· I typed in "Electrical Matches" on Google and found all kinds of information mostly related to model rocketry.· They even show you how to make them on one of the sites.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
