Motor Direction Control Help — Parallax Forums
AnaAna Posts: 2
edited 2005-04-03 22:38 in BASIC Stamp
I am working on a dc motor control project using the Basic Stamp board. I am planning to connect two pins to a H-bridge configuration with two N-Channel MOSFETS (IRF510) and two P-Channel MOSFETS (IRF9520), and a small dc Hobby motor (1.5-3V with max current load of 1A). I will use the 5v power supply on the board. The transistor switches have continuous drain current of about 6A. I am not familiar with transistor switches·and was wondering what kind of current rating would i need to run my motor. Would these MOSFETS work or should I look for others. Any help would be appreciated.
  • SunflowerSunflower Posts: 48
    edited 2005-04-03 17:57
    I am doing the same thing and have ordered SN754410 (quad Half-H Driver) from Digikey for $1.78.
    edited 2005-04-03 18:05
    I am using a seperate power source for the motors, be careful not to fry your on-board voltage regulator.
  • Rick BrooksRick Brooks Posts: 67
    Ana,
    See Gilliland's "The Microcontroller Application Cookbook", page 166 for a circuit that uses IRF511 and IRF9520. The motor is running off of a separate 12 volt supply, not the 5 volt on the board. Note that the 1K resistors to the +12 volts is a missprint. They should be 10K ohm.
    Rick
