SX18 DB9 Connection
I'm trying to interface my DB9 cable to the SX18 and I see no mention of which pins on the DB9 cable correspond to which pins on the SX18 chip. I know the OSC1, OSC2, VSS, and VDD are used, but which pins on the DB9 are used, is it the standard 2,3,7,8? If so, which pin corresponds to which pin on the chip, thanks for the help.
- Justin
- Justin
You need the SX-Key (or some other programmer) to program the SX18.
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
- Justin
You can buy the SX-Key alone for $79, but for $10 more you get the whole kit.
Bean.
www.sxvm.com
- Justin
Looks like your trying to find an inexpensive alternative to the Javelin ?
Bean.
www.sxvm.com
- Justin
