Need help selecting sensor — Parallax Forums
Patrick DPatrick D Posts: 62
edited 2005-04-02 07:37 in BASIC Stamp
I am trying to make a stamp project that will track movement in 3D.· Let's say that I need to determine where my hand is in relation to my elbow..· For example, assume I am sitting at a table in an "arm wrestling" position.· Every second, I am going to record the position of my hand by measuring the change in the angle between my elbow and hand.·· Now if in this example, the Y-axis is parallel to my spine (i.e. up and down), the X-axis is parallel to the floor and would form a plane that passes through each shoulder (I.e. left and right), and the Z-axis would represent a plane that would represent the area in-front and behind me.·
In this example, lets say I take the starting position of my hand (upright in an "arm wrestling position") and "zero" out the readings.· So, Initially, my hand starts out at an origin (0,0,0) - (for X,Y,Z coordinates).· Next, I move it forward and down so that my forearm is now parallel to the table.· Assuming that my elbow remained on the table and didn't move, and that my forearm is 11 inches, The position of my hand now be something like (0,-11,11).·
Using fairly simple math I could calculate the exact coordinates if·I know two things:
1) the distance from my elbow to my hand
2) the change in the angle at my elbow
With all that said, can anyone suggest a sensor that is Stamp compatible that could be used in a situation like the one above?·
PS - sorry for the long description and lead-up to the question, but I just wanted to be sure that anyone who answered would know what I am trying to do.·
I Have attached an Example image to help describe this...
407 x 431 - 18K
  • K de JongK de Jong Posts: 154
    edited 2005-04-01 19:47
    Hi Patrick,
    Can you use potmeters on the elbow to measure the angles? You can read a potmeter easily with a Stamp using RC-time and if you use a clever construction they may give you the XYZ.
    I have done a similar thing in 2D with small camera. But I needed a Pentium for the calculations smile.gif.
    Klaus
  • Patrick DPatrick D Posts: 62
    edited 2005-04-01 19:55
    Klaus, thanks - that's a great idea. When you say "I needed a Pentium for the calculations" do you think the Stamp would be unable to handle the claculations in my instance?
    edited 2005-04-01 20:51
    No, the Pentium was needed for the pattern recognition part of the job. Your calculations will probably fit into a Stamp. If not you can look at Tracy Allans website, he has routines to calculate fractions and large numbers. But I think you will not need that.
    Klaus
    edited 2005-04-01 21:21
    You mention measuring a 3D coordinate, but use your elbow as an example, discounting torsion of your arm in the lateral direction, that is one degree of freedom. This could be measured by Parallax's flexiforce sensor here http://www.parallax.com/detail.asp?product_id=30056·Measuring the torsion of your arm is a more complicated matter.
    edited 2005-04-01 21:34
    your right - my shoulder would have been a better example - I need to measure all degrees of freedom: flexsion, extension, abduction, adduction, Supination, Pronation, rotation, etc . I was trying to limit my example for simplicities sake. A pot would work on joints like elbows and knees, but hips and shoulders need a pot that is more like a ball and socket. Ever see anything like this?
    I thought about the flexiforce sensor but it's a little pricey - especially for prototyping. I haven't ruled anything out... Have you used them?
    edited 2005-04-01 21:44
    Patrick D said...
    A joystick pot?
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    Latest Company News
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
    edited 2005-04-01 21:45
    No though Ive entertained the idea of making a virtual glove computer peripheral using them, but that would be over $100 just in sensors. There are cheaper sensors availible such as here http://www.imagesco.com/catalog/flex/FlexSensors.html here http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=121901, it seems feasible to implement a dual angle flex sensor (a rod that would measure flexing in the 2 angles Θ and &#934[noparse];)[/noparse] but I couldn't find anything fitting the bill.
    edited 2005-04-01 21:50
    Paul - thanks for the leads on the flex sensors.·
    Beau - thanks - didn't think about that...· Do you know where I could get my hands on some data sheets?· Ever hear of anyone taking the rotational data from a joystick pot and reading it with a Stamp?
    edited 2005-04-01 21:54
    Whenever someone asks for an analog joystick I always point them to parts 252A104B60NA and 252A103B60NA at www.digikey.com
    edited 2005-04-01 22:11
    Patrick D said...
    I assume you mean to create a vector between the two pots. Depending on the data that you
    really want to react upon, it might be better to keep it separate rather than create a composite value.
    Depends on the application and/or method of data handling if this would actually be necessary.
    Latest Company News
    Mail Stop GA1
    Norcross,GA 30071
    edited 2005-04-01 22:37
    I am trying to make a motion capture suite - each major joint needs to have a sensor (aka "node") that will track it's position in 3D space.· The nodes form a hierarchal structure - think of it like a skeleton.· ·I would need each node to send data back to a PC that would then parse the data into a format that is compatible with certain animation software packages (biovision BVH).· The sensors would use vector math and rely upon data from other sensors higher up in the hierarchy.· For example, the foot node location (X,Y,Z) is determined by the combination of the changes in the hip, and knee nodes (X,Y,Z).·· I imagine the suite would resemble something like a strap-on·exoskeleton - with sensors at the joints and a bunch of cables leading back to a PC.·
    edited 2005-04-01 22:57
    This field is called rigid body kinematics or dynamics, here is a site that has links to articles covering 2D and 3D http://www.d6.com/users/checker/dynamics.htm don't know if youll find it to be very useful or not.
    edited 2005-04-01 23:18
    In a former life when I worked at a prosthetic facility we used an infrared camera with reflective markers that we placed on a patient
    to do gait analysis. We later moved to a 3D system that used 4 cameras. To keep cost down instead of using IR cameras, the markers
    that we placed on the patient were actually IR beacons that the camera was able to pick up quite nicely. (Aim the TV remote at a video
    camera to see what I mean) A simple program to "look" for a specific color generated by the IR Leds provided X and Y coordinates for
    each of the sensors from each camera. From here a 3D image could be constructed / represented to collect further information.
    Latest Company News
    Mail Stop GA1
    Norcross,GA 30071
  • steve_bsteve_b Posts: 1,563
    edited 2005-04-02 01:08
    Someone might know the name of this...and I'm too lazy to google (too many chicken wings)....
    But I was watchin American Chopper (Mikey rocks!)...well, they had a guy come out with something along the lines of what you're after....
    They had to measure the dimensions and such of a frame piece.
    This contraption was this odd looking arm with a pen on the end (with aroller).
    It didn't mimic the human arm directly..but you could certainly get almost the same dexterity. Anyhow....this had about 5 or 6 joints....single axis joints that were cambered on different angles to give the diflections you were after.
    I think the roller pen worked like a mouse basically (encoders..optical or otherwise)...and each joint had some sort of encoder...pot or otherwise that the computer would ingest and calculate (based on each sensors position) where the arm was in space....
    Seems simple enough...if you can keep the joints tight enough for resolutions sake....just the math that might get interesting!
    Steve
    http://ca.geocities.com/steve.brady@rogers.com/index.html
    edited 2005-04-02 01:59
    I want to thank all of you for the input - looks like I know what I am doing this weekend now...
    If anyone has any more suggestions, ideas, ec - please let me know
    edited 2005-04-02 02:19
    Beau Schwabe said...
    ...·A simple program to "look" for a specific color generated by the IR Leds provided X and Y coordinates for
    Beau,
    From what I have learned, the high end commercial products use optical based systems like the one you described - therefore I am assuming that it is the preferred technique.· My problem lies in the fact that although I have some programming, engineering and electronics skills, I have no idea in the least how to write a program to do something like that.· Although I do have undergraduate degrees in both Biomedical Engineering and Information Systems, I was never exposed to this type of signal acquisition and analysis, either in college or on the job.· This is why I opted for the “easy” way out.· However, I am not at all opposed to doing anything the “right” way over the “easy” way – I just don’t know where to start.
    edited 2005-04-02 03:20
    If you are "attaching" something to a person I assume ...we have found that generally people do not
    like to be tethered. With gait analysis, tethering affects the results by restricting or at least giving the
    illusion of being restricted to the subject. If you can get your head around 2D graphics, 3D
    transformation is not to difficult. There are plenty of programming books out there that deal with
    graphic manipulation. Although we had software to do the 3D stuff for us, it was open source with the
    equipment we were using. Much of the specialized graphics programming that I did was for 2D points
    and normalizing the data in a way that if someone was walking toward or away from you the graphic
    points appeared as if they were walking in place (fore shortening normalization). This particular test was
    measuring balance symmetry in a before / after situation with a particular device the patient would wear.
    Latest Company News
    Mail Stop GA1
    Norcross,GA 30071
  • kelvin jameskelvin james Posts: 531
    Unfortunately there is no inexpensive way of doing this, i wish there was. One possibility is to use a combination of accelerometers and gyros that would output the angles of movement, and using some trig math, be able to calculate the distance moved within the 3d area. But there is some error values to deal with in angular measurement which would cause a problem depending on the type of accuracy you are looking for. The more axis of movement involved, the lower the resolution. Might be worth a look at using these anyway, they interface to a stamp easily.
    kelvin
