Help with datasheet specs
I have a Kingbright dual 7-seg led DC56-11EWA (http://www.datasheetarchive.com/datasheet/pdf/85/858408.html) that I want to drive with two Fairchild MM74HC595 (http://www.datasheetarchive.com/datasheet/pdf/91/91254.html).· From what I can tell, the led has a forward voltage of 20mA.· I am using 150 ohm resistors to Qa-Qh. From what I can tell, the 595 has an abs max value for DC output current (Iout) of 35mA per pin.· With those number I thought I was safe.· However, I read another post from a few days ago stating the 595's can only source 15mA per pin.· Is this a correct for this IC?· Do I need to bump the resistors to 200 ohms?
Thanks!
Thanks!
The Electrical/Optical characteristics ARE called out at I_forward == 20 mA. Note your V_forward 'Typical' value is 2.5 volts.
(5 - 2.5) / 20 mA == 125 ohms -- not bad. (5 - 2.5) / 150 == 16 mA, still not bad. (5 - 2.5) / 220 == 11.3 mA, still not bad.
So, you can use 220 ohm resistors with this, or 150 ohms, and get good performance. I've looked at the '595 docs, and the amount of total current the chip can use depends on the IC package. The DIP has the most.
But I guess I'm out of experience at this point -- I was unable from the '595 docs to determine for sure if a single '595 could drive 15 mA (or 20 mA) per pin all driven at the same time. Anybody else done this successfully?
DTQ
Thanks!
You now have done it -- let's record the results so we have a more definitive answer for others next time.
Thanks.
1x Kingbright dual 7-seg LED #DC56-11EWA (http://www.datasheetarchive.com/datasheet/pdf/85/858408.html)
2x Fairchild MM74HC595 (http://www.datasheetarchive.com/datasheet/pdf/91/91254.html)
16x150 ohms resistors (yes, they were between the '595s and the DC56)
Your results may vary, but I ran·both with all LEDs for 45 minutes.·
