Maximum voltage on input pins
On one of my recent SX projects I mistakenly shorted my battery (6V) directly to one of the pins that I had configured to be an input when·running the SX from a regulated 5V supply.· From reading the datasheet this appears to be explained by the fact that the maximum input pin voltage is Vdd + 0.6V.
It took my by surprise since I have been using the SX chips in projects for many years and done plenty of stupid things with them and never fried one.· I guess I was due for a problem.· I don't blame the SX for the fried·pin (I did a stupid and paid the price.)·· I am just curious as to what leads to this Vdd + 0.6V limitation.· Does it reverse bias something which ends up causing a short?
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
This is also how an I/O pin with a 22 Kohm resistor can serve as an RS-232 reciever. The 22 Kohm resistor limits the current, so the protection diodes can clip the +- 12 volt signal to something the SX reads as 0v or +5v.
