BlueTooth or RF_Transceiver
I need confirmation I relate to if works good the communication among a homebot with bluetooth and a PC also with bluetooth ( it happens to me that the adapter for computer can be bought in another supplier ), otherwise I can not shop.
My problem is the following, we want to implement the monitoring system and robocup's control for comprehensive view, that is i see the playing field with camera and a server dispatch orders to each robot player according to any game strategy. There must be a communication mechanism among this server and each robot For it,¿As possible pannier to implement? ¿RF or BlueTooth?
Luis Vera
You can communicate·between multiple devices using Bluetooth or any RF system. Some RF systems incorporate an address in the protocol to allow communication with a specific device. Even if the RF system you choose does not directly support this, you can dedicate a portion of the data as the address. You then assign each device a unique number for its address. Only when the address in the data matches the device's address, does it process the rest of the data.
I hope this is clear enough for you. If you tell me your native language, I can use online translation tools to help me choose words that will easily translate into your language.
