Using SERIN and SEROUT to control a PicoPic SCC
I am trying to use the serout command to control a PicoPic servo
controller card. The variables MSB and LSB in the code below
represent most significant and least significant bytes for the
controller. I want to convert a pulse width command such as 1500ms
into this format. For example, 1500 in hex is "05DC" so I need to go
from the 1500 to MSB = $05 and LSB = $DC. The debug commands in the
code below indicate that the correct value is being assigned to the
MSB variable, but the serout command is not working because the servo
controller card gives an error signal. Thanks for any help or advice
you can give.
' {$STAMP BS2}
' {$PBASIC 2.5}
Address CON 120 'our address as a constant
OutPin CON 8 'Pin 8 used as transmit pin
Baud CON 84 'Baud rate set at inverted 9600/8/N/1
PortNum VAR Byte ' the servo to move
Speed CON 0 'speed of rotation
serial CON 16
MSB VAR Word
LSB VAR Word
LSB = $DC
SERIN serial,84,[noparse][[/noparse]DEC MSB]
DEBUG CLS, "MSBbefore = ", DEC MSB
PAUSE 1000
PortNum = 15
SEROUT OutPin, Baud, [noparse][[/noparse]Address, PortNum, IHEX MSB, LSB, Speed] 'Send
the servo command for 1 ms
DEBUG CLS, "MSBafter = ", IHEX MSB
you can give.
' {$STAMP BS2}
' {$PBASIC 2.5}
serial CON 16
MSB VAR Word
LSB VAR Word
LSB = $DC
PAUSE 1000
PortNum = 15
The problem you're creating in your code is that you're sending text (when using formatters like DEC and HEX) instead of sending bytes (do not use formatters so the values will go out as numbers).
Jon Williams
Dallas, TX· USA
