Tip: Don't. Solder a socket into the board, then put your component into the package. Use non-tacky blue masking tape to hold the socket into the board until you get it soldered in.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
Dallas, TX· USA
In general, you should use sockets instead of just soldering DIP packed ICs on a board. The heat from a soldering iron can damage the IC and soldering it directly to a board is (relatively) permanent.
Jon Williams
Dallas, TX· USA
Post Edited (Jonb) : 3/27/2005 10:25:58 PM GMT
