what causes those holes to form on my soldering tips?
Does anyone know what causes those holes/divots to form on my soldering tips? Every time I set my tip done, I place solder on it, and when I'm about to use it, I wipe the solder off on a wet sponge. Isn't this supposed to prevent corroding?
I think the corrosion is caused by me forcing solder onto the tip, instead of setting the solder on the tip to melt. Is this possible?
Any ideas?
Matthew
PS: I'm using one of those cheap $6, 30w irons.
Any ideas?
Matthew
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
Jon Williams
Dallas, TX· USA
What type of flux are you using? No clean flux is more corrosive to the tip and you'll probably get 1/3 the life compared to aqueous flux.
Just an idear,
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
My RS cheapy iron got so oxidized after about a half dozen uses, no amount of cleaning would deoxidize the tip. Thats when I opted to get a decent iron. With the amount of soldering I've ended up doing I would have had to replace the old tip at least a half dozen times. My nice iron, with regular maintenence still functions perfectly, plus I have +/- 2C control of the temperature, that the cheapy iron didn't have. In my view the iron has already paid for itself.
