Stamp and Laptops
Heres my delema.· So i got this laptop, but it lacks the serial port.· I bought the targus replicator thingy.· It's a box that hooks up to the usb port and have an out for for serial, paraller, ps2, and more usb ports.· So I hook up my Stamp2 but it doesnt show up when i run indentify.· I double checked everything, still nothing.· I hooked up the stamp to my desktop machine (that has a built in serial) and worked fine.· Then I hooked up my external modem to the replicator, just to see if·the replicator·works properly, and it does.· So both the Stamp and the replicator seems to be working fine, they just dont like eachother.· Any ideas on how could I fix that problem?
I don't know about the Targus adapter -- usually Targus is pretty good. What can happen is the vendor takes shortcuts with the RS-232 'handshake' signals. Unfortunately, the BS2 uses the DTR signal to reset the device -- and that's one of the handshake signals the vendors don't support very well.
If it is adjustable, you could disable the FIFO (if any) on the Targus serial port.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
My Laptop is Toshiba Satellite .
First I though that my COM port was damaged . but I remember ,I've read
something in the manual (Homework BS2) ,that some laptops are not suited
to work with the BS2 interface. It seems that Laptop COMs are configured differently that the desktop ones.
I tried the same BS2 On my desktop and it works fine.
With many of the Toshiba laptops you have to disable the FIFO buffer to get the serial port to work correctly with the Basic Stamp. This one stumped me for a while with my older Toshiba.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Jon Williams
Dallas, TX· USA
(The USB cable is hidden under a cover )
Mine will not work with my BS2p, any PalmPilot I have(I have a lot, from the old 5000 to the Zire) or any of my Psion PDAs...
No matter what I do, I can't get it to work, and according to what I hear from fellow Psioneers, neither can anyone else.
The only reason I haven't junked it is that I need the parallell port sometimes...
(Whenever I need a colour print and am too lazy to pop by the office and use the lasers there. B/W prints I do on my USB enables laser printer
Targus makes good cases, but electronics? nope...
