SX28 to SX18
Is there any difference between programming for a SX28 to an SX18??
I've got a nicely working program on an SX28, which Im trying to use on a SX18.· I've modified the DEVICE setting to SX18.· Using same resonator etc.
The SX18 seems to just spit out gibberish - its a serial -2- serial buffer application.· The SX28 works perfectly.
The SX18 is on a prototyping board - wired up as in the SX-Tech board diagram.
Cheers
James
Cheers
James
Can you post the code ?
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
Thanks for the idea - suddenly thought to double check the DEVICE lines. RC was being initialized which Im sure didnt help! Also seems the OPTIONX parameter seems to bugger it all up
Works now!
Cheers
James
