Can Controller for LCD be changed to control LED board?
This is just a very general question.· I do not have any experience dealing with BASIC Stamp and the LCD's.· I was just curious if I put LED's on a circuit board with the same amount as the pixels on the given LCD board controller id use.· Is it possible to do this?· Basically trying to make a custom sign for my business...the cheap and labor intensive way.· Any thoughts on the idea would be appreciative, thanks.
csavage@parallax.com
It will also pull more power. An LCD is a very low power device compared to an LED driven sign. But that's a good thing -- the LED version will be much more visible.
Note they do manufacture small LED blocks of 5x7 LED's each which can be used for this purpose. That's what commercial scrolling signs use.
In all fairness you should be told it's probably much easier and cheaper in the long run to get one of the commercial units -- I think CostCo has them for less than $300. Not nearly as much fun, or as much control though.
Best Regards,
Vollord, you may want to look into using LED display modules like shown here: http://www.parallax.com/detail.asp?product_id=28099·but again an LCD controller could not control one of these.
Post Edited (Paul Baker) : 3/24/2005 5:17:25 PM GMT
·· My question was based on pixel equivalency...Which means that VFD Displays qualify, since they're basically the same pixel configuration as LCD, except that they're lit up.· In that context, VFD could almost be compared to an LED version of LCD, if you were somehow able to make pixel-sized LEDs that were on the board.
·· As for cost, a VFD display would be a lot cheaper than discrete LEDs trying to do the same thing with the same resolution.· Again, this is based on the assumption that the OP was looking for an LED version of LCD Displays.· Just as some people prefered the older LED Wrist Watches to the new LED ones, since you could read those at night without a light.
