POV (persistance of Vision)
So I was sitting around tonight and I wondered if I could make my BS2 (I guess Rev G) BOE rev C do Persistence of Vision.(move LEDs back and forth fast enough while the LEDs turn on and off makes words appear in air.)·Now first I am not an engineer nor do I play one on TV, I have no idea what is involved in this I just thought I would tinker.
So I hooked up 9 LEDs and 9 470 ohm resistors and a common ground. I used pins IN0-IN8
First I tryed some simple commands to the BOE i.e.:
'·· {$STAMP BS2}
'·· {$PBASIC 2.5}
Main:
· DO
· GOSUB All_Off
· GOSUB All_On
· LOOP
[noparse][[/noparse] Subroutines ]
All LEDs off
All_Off:
··· LOW 8
····· LOW 7
······· LOW 6
··········· LOW 5
··············· LOW 4
··················· LOW 3
······················· LOW 2
··························· LOW 1
······························· LOW 0
All_On
All_On:
· HIGH 8
··· HIGH 7
····· HIGH 6
······· HIGH 5
········· HIGH 4
·············· HIGH 3
··················· HIGH 2
························ HIGH 1
····························· HIGH 0
This blinks them on and off or should I say flickers. I add Pause 500 and turned some on some off you get the idea.
So just from this little experment should I assume that POV needs a Timer, that simple letting the code loop is not enough of a delay? (you know like ON is a drum beat on off on on off.)
I mean the idea is a pendulum swinging back and forth spelling letters and what not. Any thoughts? I mean even if this can't be done without an external time I think I still want to try and write a program that blinks the LED's because then I want an Idea of how to write tighter code, which I assume means to pratice.
Anyway I'm not curing cancer just foolin around any ideas?
Ray
'·· {$STAMP BS2}
'·· {$PBASIC 2.5}
Main:
· DO
· GOSUB All_Off
· GOSUB All_On
· LOOP
All LEDs off
All_Off:
··· LOW 8
····· LOW 7
······· LOW 6
··········· LOW 5
All_On
All_On:
· HIGH 8
··· HIGH 7
····· HIGH 6
······· HIGH 5
········· HIGH 4
Ray
Setup:
· DIRS = $01FF
Main:
· DO
··· GOSUB All_On
··· GOSUB All_Off
· LOOP
· END
All_On:
· OUTS = $01FF
· RETURN
All_Off:
· OUTS = $0000
· RETURN
Jon Williams
Dallas, TX· USA
I like the idea of using a stepper motor as the basis for the whole system, using a DC motor to drive the stepper as a generator, having the STAMP and all other electronics mounted on the driven stepper, and using the power generated by the driven stepper to run the electronics. No brushes required.
Bruce
Work:· Clemensb@otc.edu
Good Stuff on my Blog: http://theDeadBug.journalspace.com
And dead bug I was going decidedly more low tech
Ray
OUTS = %0000000100000001
BTW ... all of this is in the manual and help file (hint, hint).
Jon Williams
Dallas, TX· USA
Ray
Thanks again Jon (much more eligant to us outs than High, Low away we go)and Deadbug. Now how can I make the toliet seat go down on its own....
Cheers,
Ray
It is a great book and I strongly suggest it to anyone who is into Stamps.
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
