why are slider-pots so much harder to find than rotary pots?
i've been trying for a while to find a source of slider-pots, preferably small ones, and i've only found some at a local surplus place (got lucky), or some huge ones at a local electronics store.
so i was wondering, why are slider-pots so hard to find?
and even better, where can i find them (in non-industrial quantities)?
thanks,
matt
thanks,
matt
one other question. to use these sliders with a BS2, what should i look for in the specs? the rated voltage seems to usually be 150V or more, so that would work fine with the 5V or less that the BS2 puts out, right?
thanks a ton!
<EDIT>·changed instructions of using POT to RCTIME since request was for use in a BS2 </EDIT>
Post Edited (Paul Baker) : 3/23/2005 9:05:47 PM GMT
Electronic Goldmine(go to 2nd page): http://www.goldmine-elec-products.com/products.asp?dept=1111
Have you seen the digital pots?
Post Edited (Jonb) : 3/23/2005 9:28:13 PM GMT
All proffesional boards use the sliders as input to a controller which then sets the gain of the amplifier, this overcomes the crackling that happens when moving the slider when feeding the audio signal through the slider itself. Also the controllers employ techniques similar to switch debouncing to make the audio transition smoothly even if the change presented by the slider is noisy or erratic. They also circumvent the blind patch problem by knowing that the current position cannot jump to a far different value without going through the values between.
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
to bugg: sliders are obsolete? can you explain? are there digital slider pots?
matt
EDIT: it's strange, i tried The Electronic Goldmine before, but i searched for "slider" instead fo "slide", so i got nothing. they seem to have incredible prices (a package of 2 or 4 for what you would pay for only 1 at mouser). so thanks a lot for pointing that out.
Post Edited (tangramkid) : 3/24/2005 1:05:35 AM GMT
bugg
Boe-bot: $229
Toddler: $249
Also, it is quite possible to create a 'sealed' application. If you assemble them in a very clean, dust-less environment - you can extend the life. [noparse][[/noparse]make a box that is a mini-clean room and put only your hands inside?]
G. Herzog in Taiwan
