Opto input from 2v to 400v
Hi Guys
Does anyone have a diagram for an opto input circuit for a BS2 which switches at not more than about 2.5 volt and can handle a continuous input of up to 400 volt. It would be useful if it also had an LED to·indicate input status. I have +5v regulated and +12v unregulated on the board.
I'm tired of smelling the acrid whiff of blown Optos, transistors and zeners.
Thanks a lot and kind regards from Kwa Dukuza
John Bond
ps. My response may be·erratic because we're experiencing telecom (telekom, Telkom, phone)·problems.
John Bond
Jon Williams
Dallas, TX· USA
If it is not signal noise you are worred about then:
If it is 2.5 volts, then why the need for 400 volts?
If it is 400 Volts, then why the need for 2.5 Volts?
If you need to monitor a level from 2.5 Volts to 400 Volts then use a voltage divider and an A-D converter.
I use this method to monitor Plasma Cutting Torches from 0 volts to over 400 volts with a Stamp.
Then you can set the trip point in software, and vary it if necessary.
Hope this helps you out,
Alann Bradford
Plasma Technologies
