Using OEM parts in my design
Im now happy with my design and wish to make 5-10 units ..
i understand i can purchase OEM parts , interp chip , resonator , eeprom to save costs.
my question is .. is the voltage reg IC 100% nessicary ? does this ensure the stamp is not damaged by too much current on the pins?
the other components i assume can be replaced with normal sized components , transistors and resistors ..
thanks in advance.
thanks in advance.
But make sure the ic's are properly bypassed with capacitors.
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
"A problem well defined, is a problem·half solved."
There's another chip, though, which resets the Interpreter if the voltage drops too low. I can't see it in the OEM kits, but it is mounted on the ordinary modules. If you're working with a battery-powered system, one of those would be nice, as there's no telling what the BS2 will do if the voltage drops too far. (I suggest checking the tolerances for the Interpreter, EEPROM and whatever else you're using to see what they're OK with, but I think a 4.2V chip is used on the BS1)
NOTE - MY APPOLOLOGIES TO PARALLAX FOR OFFERING CUSTOMERS A LESS EXPENSIVE ALTERNATIVE... I AM A HUGE FAN AND KNOW THAT THE COMPANY CAN ONLY GROW AND GET BETTER BASED ON REVENUES, WHICH MY SOLUTION IS REDUCING. SORRY!
However, you will need to get +5 volts from somewhere -- but if you already have your own power supply providing +5, then you don't need the regulator to do it again.
Now, if you want to program the BS2 in-circuit, you'll also need the transistors for the programming port, and the reset circuit. Steve's idea of using a 4-pin jumper to connect a removable programming pigtail is a good one.
is this part nessicary ? is this also the part that protects against brownouts?
ive looked at the PDF showing the layout on the actual stamp but if anyone has another layout i could study this would be great!
It is only used when you feed the BS2SX power from another source, like a 9V battery.
No, it doesn't provide brownout protection.
