Help? how to input sound data coming from a mic into basic stamp
I have a sound project, thats needs data from the mic. Not sure how would it get into Basic Stamp, maybe a using Max MSP
Do you need to aquire the data in real time or not? If so your going to run into problems with aquiring fast enough to produce any sort of fidelity of sound.
You could put some stepper motors on some faders and have the stamp monitor voltage peak levels on 2 channels and have it automatically fade over when a certain circumstance arises (programmable).
You can use the stamp as an IR audio switch connect to some solid state relays that would 're-route' audio signals to different devices!!
You might be able to have the stamp monitor a for a given frequency or pulse width that's inherent in a given audio signal (as a tuner...)and display or do something....
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
I've done projects where I took live sensor data from Basic Stamp into Max/Msp, but unclear if it works the other way around.
Certainly the stamp can read RS232 data.· How fast is it coming out?· is it in packets or a constant stream?!
Steve
The Basic Stamp is a mirco-controller with a reasonable EEPROM for a controller program, but it isn't a micro-computer or a data buffer.· The amount of audio that you can put into its 'scratch pads' or registers may not be much use to you - unless you merely want a noise to trigger a complex program routine.
G. Herzog in Taiwan
