USB Oscilloscope
I bought a Parallax USB scope and I now have a few questions about how to use it for my work.
1.· I need to·examine noise on top of power supply voltage.· 5V and 10 Vdc.· This USB scope apparently cannot be set to AC coupled, so with 100 mV vertical I can't see the trace.
2.· How to calibrate the scope range, or span.· "Calibration" only adjusts the zero.· It reads 9.91 V when my dvm reads 10.090.·
Maybe I expected too much for $130 ...
Andyh
Andyh
The current software does not have calibration for the span (or dynamic range).· I am working on new software at the moment and I might add this later.· Really this scope is not accurate enough for measurements that require calibration.·
If you would like to help beta test the new software email me at : dpientak@parallax.com.·
The reason I suggest this is the new software has a variable dot persistence mode that is great for looking at noise.·
Hope this helps,
Doug
