Newbie question about program execution speed
Greetings all -
So the specs say 4,000 instructions per second.· When I program
DO
num·= num+1
debug ? num
LOOP
I get up to 2800 in a MINUTE.
I'm going to be looking at monitoring 10 channels of digital inputs, and I need to know how
fast this dude is really checking the inputs....· Is the problem that the Debug command slows
things down?
I know this is a silly question, but i did try to check the FAQ !
Thanks much.
DO
num·= num+1
debug ? num
LOOP
things down?
Thanks much.
If it takes 60 seconds to get 2800 messages, you are getting
46.6666 messages/second, or 21.42 mSec/Message.
A direct replacement for the debug statement is:
SEROUT 16, 16384, [noparse][[/noparse]"hi"]
The Debug statement runs at 9600 baud. The "?" in there outputs
"num = 1000" -- putting up the "num =" characters. Thus, for each increment,
you are sending 11 characters. Now at 9600 baud, a character should take
about a millisecond. Yours seem to be taking twice that -- unless your
'num' above is not really what you've named your variable?
A MUCH better test is:
MAIN:
Debug "Start"
Num = 0
WHILE NUM < 4000
Num = Num + 1
WEND
DEBUG ? Num
GOTO MAIN
Now, you should time the amount of time between two 'DEBUG' outputs. That
will give you a MUCH more realistic execution time.
P.S. I usually use the number of 300 uSec per instruction when programming the BS2.· This is for 'normal' instructions.· SERIN/SEROUT, PULSIN/PULSOUT, SHIFTIN/SHIFTOUT, and PAUSE instructions are more dependent on the data than on the instruction timing.
P.P.S.· The BS2p is about 2.5 times faster than the 'stock' BS2, and the BS2sx is faster yet, I believe.
I was using "counter" I believe.
I'm used to PLC's and such, and as a mechanical type, forget silly things like the fact that messages don't get sent magically.·
Thanks again,
ZB
Main:
· DEBUG "Start", CR
· num = 0
· DO WHILE (num <·4000)
··· num·= num + 1
· LOOP
· DEBUG DEC num, CR
· GOTO Main
Jon Williams
Dallas, TX· USA
Support, is there a way to determine the actual number of instruction?
Larry
PBasic is a 'tokenizing' compiler. There's an on-PIC library of code (burned in, hard-coded) that runs a PBasic interpreter. The IDE compiles your PBasic source code into PBasic 'tokens' -- a 'token' is basically an integer, one per PBasic keyword. The 'tokens' are downloaded into the BS2 eeprom. When the BS2 is reset, it begins reading tokens from the eeprom and based on the token runs the respective library code in the PIC. Then it fetches the next token from EEPROM.
So the PBasic run-time can do this to 4000 tokens per second.· 'Timed' tokens take longer -- SEROUT/ SERIN/PULSOUT/PULSIN, etc -- there the execution time is based more on the data, or the length of pulse, than the Token interpretation time.
And the way to determine the actual number of PBasic tokens you have is to look at the 'memory map' once your program is compiled. "DATA" is stored from location zero up. The code tokens are stored from high-memory down.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
