Running speed comparison , BS2x , and SX/B
What kind of speed increase should i get when designing my project on the SX/B , ( i will slowly add assembly as i learn it)
my main reason for choosing the sx is the cost for small scale runs of my intended project
which is a MIDI controller for live performances and the extra speed i may gain.
i have made this project already using a BS2p and it works great but i would like to take it the next level
with improvments in speed , and also adding a MIDI INPUT port which i understand the BS series doesnt quite have the juice for in the serial department
can anyone give me a rough idea of what the SX/B can do compared to the BS2SX
thankyou.
thankyou.
Like I said in that post, its an apples to oranges comparision, it all depends on the exact command your refering to. But in essence your looking at many hundreds of times faster to thousands of times faster.
understood , i was just after a rough approx , which is what you just gave me [noparse]:)[/noparse]
thanks for the help!
I think Jon Williams is working on a MIDI project with SX/B.
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
"A problem well defined, is a problem·half solved."
Now, having said that, I need to add that the BS2 is running 'Basic' tokens, so each one does quite a lot. The SX is running assembly instructions, each of which is quite simple. When you add SX/B to the mix, each Basic instruction gets converted into a few to many assembly instructions -- that will reduce that 5,000 times down to maybe 1,000 times faster.
And as Bean has pointed out, many applications are "I/O Bound", meaning sending and recieving data, and waiting for data, take up most of the execution time. If you are I/O Bound, a BS2 will spend 1 mS figuring out what to send next. An SX28 will spend 1 uS figuring it out, then both will take 1 mSec per character to send the result at 9600 baud.
