Run 1, Run 2 Multi Slots---Got a problem
I have been trying to get my bs2sx to work on different slots.
I know I must be doing something wrong, but just can't seem to figure this out.
Attached is a sample programs right out of the book, will not work!!!
I download Run1.bs2 then I download Run2.bs2 and I only get the last download to work, or basically Run2, it never goes to slot 1. Any help would be appreciated
Thank You
Guido
Thank You
Guido
' {$STAMP BS2sx, RUN2.BS2}
This will tell the compiler to tokenize RUN2 and download it into slot 1.
Jon Williams
Dallas, TX· USA
If you want to load BOTH of them into the Stamp at the same time, you must use this extended form of the $STAMP directive:
' {$STAMP BS2sx, RUN1.BS2, RUN2.BS2} ' for two programs
This same directive can be used to load up all 8 slots, using the same conventions:
' {$STAMP BS2sx, RUN2.BS2, RUN3.BS2, RUN4.BS2, RUN5.BS2, RUN6.BS2, RUN7.BS2 etc}
Bruce Bates
' {$STAMP BS2sx, SLOT1.BSX, SLOT2.BSX, SLOT3.BSX, SLOT4.BSX, SLOT5.BSX, SLOT6.BSX, SLOT7.BSX}
After your SLOT0.BSX program is saved with this definition, it will automatically load all the other slot files into the editor the next time it's opened.
Jon Williams
Dallas, TX· USA
Thank You both very much
Guido
