SX-Key and VMware
Helllo
Has anyone been ablle to use the SX-Key under VMware. I have tried versions 4.5 and the new beta 5 and every time I attempt to assemble I get an access violation in SASM.dll. This does not happen under WinXP as a host OS but only as a guest OS under VMware. I am running WinXP (32 bit) under beta 5 on a Linux (Fedora Coere 3) host using and AMD64 system.
I've never had the chance to run the IDE on an Athlon64. Of course, in the interests of science (and compatibility testing), I'd be more than willing to... if Parallax sent me one! Ken?
Thanks, PeterM
I also use VMware, both Workstation and ESX server, and have noticed that some applications that are time sensitive have issues (in my experience NTP time sync server does not work as expected). I don't know if this would affect the SX-Key interface or not.
FYI,·I am due to have·an Athlon64·delivered this week to upgrade one of my machines. Onboard serial plus 2 extra·serial ports (Aftermarket PCI·card). It will be running WinXP Pro...··
If I run into any issues, I'll·be sure to·keep you posted.
-Dan
Please do. It's always good to hear what works and what doesn't.
Thanks, PeterM
