Aliasing
I have a variable - "sertext var byte(12)".
This variable is used once at the beginning of the program cycle, and changes each time the program cycles.
I have tried aliasing like this:
a· var· sertext(0)
b· var sertext(1)
but the program will not accept it.· Is there any way to alias the bytes in sertext - I need more variables but RAM is full.· I am using a BS2P24 at the present time.
Sid
a· var· sertext(0)
b· var sertext(1)
Sid
Instead of...
myText····· VAR···· Byte(3)
Do this:
myText······VAR···· Byte
myText1··· ·VAR···· Byte
myText2···· VAR···· Byte
You can still treat "myText" as an array of three elements, and now the compiler will let you alias the individual entities:
header···· ·VAR···· myText
cmd········ VAR··· ·myText1
dByte······ VAR···· myText2
Jon Williams
Dallas, TX· USA
a· var byte(12)
a· var byte
a1 var byte
a2 var byte
and so on.
Sid
As Jon stated: "You can still treat "myText" as an array of three elements, " so the concept can be expressed as:
myText VAR Byte
myText1 VAR Byte
myText2 VAR Byte
and you can address
myText(0) which will equal myText
myText(1) which will equal myText1
myText(2) which will equal myText2
Or am I missing the boat, Jon?
Jon Williams
Dallas, TX· USA
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
"A problem well defined, is a problem·half solved."
