MAX/MSP communicating with basic stamp
Hi
I'm having trouble sending data from the stamp to the serial object in Max/msp. Neither debug nor serout are working (max just hears nothing). has anyone gotten this to work? if so, how? it may have sometihng to do with baudrates, but i'm not sure.
btw, i'm on a mac with a keyspan usb-to-serial adapter.
sorry if this post is too off topic, i didn't know where else to go.
If the baudrate is wrong, that would cause problems, but usually you will receive junk.
Are you shifting the voltage levels from the stamp with a MAX232 chip or anything else ?
The stamp sends serial data using 0volts and +5volts. The serial port on a computer uses +12volts and -12volts.
Some computers will accept the 0 & 5volt data, many will not.
Also make sure you use the "inverted" serial baudrate on the stamp.
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
"A problem well defined, is a problem·half solved."
aparently i didn't need a MAX232 chip, which is good. didn't want to have to wait for that teeny little thing to ship.
thanks a lot
EDIT:
well, now, for some reason i'm getting junk numbers again. i'm reading a potentiometer, and it was working before, but now i get all zeros, and some random numbers sometimes when i'm changing the potentiometer.i don't hink i've changed my code at all, this just started.
I've got a basic RC circuit, with this code:
RCVarW VAR WORD
RCVar VAR BYTE
main:
'take pin high to discharge cap
HIGH 12
'hold 1 mill to make sure cap is discharged
PAUSE 1
'measure time it takes to discharge again
RCTIME 12, 1, RCVarW
'scale down to something < 255
RCVar = RCVarW / 300
'send the result
SEROUT 16, 16780, [noparse][[/noparse]RCVar]
GOTO main
i'm worried that i broke my stamp somehow
Post Edited (tangramkid) : 3/19/2005 2:58:27 AM GMT
