Field sensors.
Ok, here's a small project I want to complete, but I'm stuck
I want to be able to project the location of object within a given area.
Say the size a baseball field or a soccer field.
Couple of things I have thought so far:
A) Use some kind of radio transmitters at the four corners and meaure the time the signal takes to get to my object from these transmitters. Use this information to triangulate a location.
Any ideas ?
(My first thoughts were to do this so I coudl preprogram something say like a lawn mower, (I haven't addressed the multiple safety issues with this yet, but I know there are many)).
Post Edited By Moderator (Aristides Alvarez (Parallax)) : 3/16/2005 6:04:12 PM GMT
Any ideas ?
You could use more than one at each corner, it depends how accurate you want it to be.
It woulld be cheaper-easier to do than a rf signal.
Bob N9LVU
I did my master's thesis working with high frequency audio communications (not ultasonic but it suffers from the same problems even more so). Emitters (speakers) become more unidirectional the higher the frequency, this is due to both the characteristics of the sound itself and the resonant material used to produce them, the object would require an·entire array covering the surface of the object. Our lab contemplated object location using ultrasonic but abandoned it because it was too directional and subject to being eclipsed by barriers. ULF (ultra low frequency) doesn't suffer from the same problem, except the diaphram required for it·is huge. one final problem with ultrasonic communication is that the higher the frequency the larger the absobtion rate of air is, for the distance he is talking about your likely to need an emitter of 200 dB or more.
RF is the way to go in general but the stamp is really slow. To give you an idea of what we are talking about, the RF will travel one meter in 3 and 1/3·nanoseconds corresponding to a sampling frequency of 300MHz
Post Edited (Paul Baker) : 3/16/2005 2:08:50 AM GMT
light sorce. Then you could read the direction the detector is pointing to, and triangulate from multiple detectors. The more detectorsyou use,
the better positional accuracy you would have. This would be much easier on a stamp, as it would not require high speed.
Bob N9LVU
I would use a cat5 cable for power and coms to each slave, diasychained for simplicity.
You could do it with doppler rdf, but this would be MUCH more accurate, and lower in cost.
Bob N9LVU
If I wanted to keep track of a lawn mower in a baseball field, I would probably use several base posts with dirrectional sensors mounted on a rotating base, and then a modulated light source on your target (lawn mower).· Think Flashing beakon on the lawn mower, and then toilet paper tubes mounted on servo's.· Look through the toilet paper tube and see the flashing beakon, then (based on the signal to the servo) yoiu know what dirrection the lawn mower is.· you could use a single sensor per base station (think old school radar, you get a blip when the sensor passes your airplane, but no distance information) or 2 sensors, per base station, and create a dead band between them.· WHen the right sensor sees the lawn mower, the servo turns right, until it doesn't see the lawn mower.· 2 stations make a triangle, a triangle tells you where the lawn mower is.·
Accuracy is going to be limited by how how small you can get your dead band, and sensing range will be limited by how bright your flashing light is.·
Of course, instead of a flashing light, you would probably want to use a modulated IR transmitter like a TV remote, and instead of toilet paper tube...· something easier to work with.·
You'll want a remoted lawn mower kill switch, and I fear for small children and rabbits.·
i'd create a separate intake chute just for them.
muwahahaha....
daniel woolston
Teksystems Inc.
www.danwoolston.com
Although I have a Engr. degree, I concentrated in high power and control operations, so as I understand the talk of using RF, implementing it is going to be a little difficult.
A friend of mine has a set of bincoluars that have a range finder on them. I belive it is some kind of infrared system. As I think about pricing and time invested, I'm thinking this might be the best route to go with this project.
Post Edited (m_fabio2) : 3/16/2005 11:27:59 AM GMT
at least you'd have boundaries set. it wont help for guidance, but limitations will be set.
daniel woolston
Teksystems Inc.
www.danwoolston.com
http://www.iis.fraunhofer.de/ec/navigation/tracking/index.html
This appears to be exactly what you want to be doing, but be prepared to whip out your German to English Dictionary, because produktbrosch
Check out this robotics site. www.convict.lu/Jeunes/RoboticsIntro.htm
Don't let the word convict throw you. Much of the navigation info on this site involves measuring time and phase differences and triangulation. VERY good stuff.
Rick
