Does anyone have the code for a double digit counter using one switch?· attached is the code for a single digit counter with a switch.· Can i modify this code?· I'm using the BS2 on the NX1000.
If you're using 7-segment outputs you'll need to mutliplex them as the data lines are all common. This is a little tricky, but there is an experiment in StampWorks that shows you how to do it manually.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
Dallas, TX· USA
csavage@parallax.com
Jon Williams
Dallas, TX· USA
