Question about multiple LEDs, sound activation & power...
Any suggestions or advice would be appreciated:
I am trying to design the most efficient way to run approximately 60 LEDs, grouped as four, eight, sixteen and 32 (ie groups will be on together)- I want to use a BS2 (or BS1, possibly) to control the groupings of LEDs turning on and off driven by sound (like a meter on a stereo)- and I want to run off of batteries for approximately 6 hours (or more)-
I plan on using a carrier board for the BS2s power (9v and voltage reg. to get my 5v, a home brew board)- what do you think the best way to power the groups of LEDs will be? (As in what battery pack setup would you suggest?) I'm thinking C or D cells here, any help?
I'm also looking at the MAX7219 from Parallax (because I already have one) to possibly assist in driving the groups. (Overkill? I haven't used a 7219 before, so I thought it might be a good way to learn about it...)
What do you think?
(And just for grins I think I'm going to try and do this project with a BS1 or BS2 then re-create the entire thing with the SX chips...also for a learning experience)-
Thanks!
What do you think?
Thanks!
For the BS1 you'll have to synthesize the SHIFTOUT function as it is not part of PBASIC 1.0.
Jon Williams
Dallas, TX· USA
Jon Williams
Dallas, TX· USA
Another possibility is 8 74HC595 chips. These will give you MUCH greater control of individual LED's, but give you the added difficulty of pre-figuring your patterns and putting them into the EEPROM as DATA statements. It's also more hardware -- a resistor per LED, and the chips themselves. The '595 can drive larger currents than the BS2, so 8 led's off a 595 is no problem.
You can drive a '595 with the SHIFTOUT statement. Daisy-chain them together and this takes 3 wires -- data, clock, and ground.
Note all 60 LED's on at the same time takes 900 mA -- worst case would be 900 mA for 6 hours, or a 5.4 A-Hour battery.
Post Edited (allanlane5) : 3/15/2005 7:10:04 PM GMT
Am I correct in assuming that if I use the MAX7219 the max draw at any single time would be the equivalent of 8 LEDs (because doesn't the MAX7219 just pulse the 8 segment groups?)- so when you figure the limiting resistor value you really figure it for a max of 8 LEDs at a time, right?
Thanks again!
Jon Williams
Dallas, TX· USA
Below is a brief excerpt of a posting several months ago that describes how to control different levels of brightness.
;INTENSITY - Address $XA
;Options·$00 = minimum intensity
;$FF = maximum intensity
;See MAX7219 data sheet for resistor selection and current
;To set "medium" intensity ( I had a 47 k ohm resistor from pin 18 of the 7219 to vcc)
The bs2 code to do this is:
'Set intensity of LEDs
'LSNibble 0 = min intensity and F = max intensity
Intensity:
· LOW Load
· SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]$0A07\16]
· HIGH Load
· RETURN
http://ourworld.compuserve.com/homepages/Bill_Bowden/555leds.gif
and it works fine. Now I think I'm going to use that as a base, and add in the BS2 so that I can control 'groups' - I'm going to use 4 AAs (6v) to power four 'sets' of LEDs and give the BS2 it's own 9v on a mockup super carrier. Using two seperate power sources, will I run into a problem with 'uncommon' grounds that anyone can see? (I don't have much experience using multiple power sources like this-)
Ryan
To answer the question it depends on how you will enable the 555-LED circuit. Can you post a schematic that shows your plan to enable the 555-LED circuit?
