continous rotationing servos
····First I would like to thank all of you for the help with my PSC problem. I got it working· with your help.· One of you guys mentioned a countinious rotating servo· could you tell me how to do it with a JR· servo.
![turn.gif](http://forums.parallax.com/images/smilies/turn.gif)
http://www.uoguelph.ca/~antoon/gadgets/servos/servomod.html
Basically you just search "Google" for "Servo Modification."
BTW, did you get my test code to work?· What revision firmware?· From this thread:
http://forums.parallax.com/showthread.php?p=529554
csavage@parallax.com
thanks Walt
·· I'm a little confused about your results.· If you used !SCID and it worked, you should be seeing a version number of 1.0 or 1.1
·· Version 1.3 would've supported the !SCVER command I posted in the code originally, but not !SCID.· Are you sure of the number?
·· By the way, what was wrong with the servo?
