SEROUT over COM2 to VB6 MScomm.Input
Tired to find an answer to this using Search, but didn't find anything. It seems like this would be a pretty common thing to want to do so sorry if this has already been asked and answered. Anyway...
I'm using a GUI written in VB6 to set a series of variables that my BS2p will use to run a series of heater/time events. I can set the variable in VB and send them to the stamp with no problem. MSComm1.output to SERIN 16,16624, variablename yada, yada, yada... This works fine. I know the stamp is reading the variable correctly because I set a LED to flash the number of times that "variablename" is set to (I can't use DEBUG variablename because COM2 is tied up by VB).
Then I'm trying to bounce the variable back to VB. This is not working for me. SEROUT 16, 16624, [noparse][[/noparse]variablename] sends data to VB. VB captures data with the OnComm event. However, I can't consistently read the variable correctly. Sometimes I read it correctly, but most of the time garbage characters are displayed by VB. It seems like I've got some kind of data type or size mismatch. I've tried changing both the output and input variable type (string, variant, etc.) and the format of which it is sent and received (DEC variablename). No luck converting once back in VB either.
Any ideas? Is there anything unusual with the way the stamp formats and sends data over pin 16? Special settings in VB to read a stamp? Thanks for any help.
Jon Williams
Dallas, TX· USA
2. Your value of 16624 ( = 240 + $4000) should give you Inverted, 9600 baud, 8-data no parity. This is correct for the BS2p.
3. You are aware you can only send and recieve 8-bit values, right?
4. It is least error prone to send as strings from VB (with an ending CR), receive as DEC VarName. Going BS2 to PC, send as SEROUT 16, [noparse][[/noparse]DEC VarName, CR], recieve as string in VB, toss any echo, and convert to value.
5. Sending in 'binary' (the default -- Value '10' becomes byte 10) it can be much harder to throw away echoes, and find the 'real' data bytes.
I'd really like to use the DB9 provided on the Stamp board if possible.
I think the BS2 echo when I set the variable may be what is causing my trouble. How do I "toss the echo" in VB?
Get what comes back, read that many characters, ignore what they contain, then read the BS2's response.
If that's too risky for you (and it would be too risky for me, by the way) then preface the VB outbound message with a particular character -- like a "!", and end it with a particular character, like a CR. Have the BS2 'wait' for the "!", then read its data. Have it send back to the PC with a different start character (like a "*").
Then, on the PC, read each returned line. If it starts with a "!", then read the next line. If it starts with a "*", then use the data.
PC --> [noparse][[/noparse]PC Hdr] [noparse][[/noparse]data0] [noparse][[/noparse]data1]
PC <-- [noparse][[/noparse]PC Hdr] [noparse][[/noparse]data0] [noparse][[/noparse]data1] [noparse][[/noparse]Stamp Hdr] [noparse][[/noparse]data0] [noparse][[/noparse]data1]
It's now very easy to move through your input buffer to look for the Stamp's header, then grab the data that follows.
Jon Williams
Dallas, TX· USA
My whole point to reading the values back from the stamp is to display them in a VB dialog box. That way the end user will be certain what values were programmed into the stamp. Since the stamp is alreading sending this back I'll just use it. No need to resend with a SEROUT command.
I was actually complicating things by trying send back the data.
Seems to be working now, at least for one variable. Hopefully things will hold together when I add the others. It should. Thanks again for the help!
Jon Williams
Dallas, TX· USA
Jon Williams
Dallas, TX· USA
