Newbie can't get started with USB BOE
Hello, I just got a BS2 with USB BOE and 9v AC adaptor. It says yes for loopback and echo, but does not show anything in the device type or version fields. I have the BS2 installed correctly, power is on and switch is set to 1. The USB device is recognized by the computer and pings when I plug it in. The device mgr says COM3 is the USB serial port, is working properly, and a FTDI driver is installed.·I also get an error when trying to download any software to the device (just to test it). I also re-installed on another computer and same thing.
Help! Any thoughts are appreciated.
Marc
Post Edited (Marc) : 3/12/2005 10:47:23 PM GMT
Marc
Start >> Control Panel >> System >> Hardware >> Device Manager >> Comx
Right click, then Properites >> Port Settings >> Advanced
I've read two different solutions, but can't explain why they work:
1) Under BM Options change the Latency Timer to 1
2) Under Misc Options change the timouts to 100 ms
Jon Williams
Dallas, TX· USA
·· Where did you get your FTDI Driver?· Did you download it from the Parallax Website, or did it come on a CD?
csavage@parallax.com
Jon Williams
Dallas, TX· USA
OK, I'll call on Monday. thanks anyway for the feedback on a weekend!
Marc
