Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Add Servo — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Robotics
Add Servo
GHJN14
2
2005-03-11 23:25
edited 2005-03-12 00:25
in
Robotics
Is is possible to add a extra servo to a BOE board even if all four slots are full?
allanlane5
3,815
2005-03-12 00:25
Yes, you can wire one to the bread-board area. The Red wire is +5 (or Vdd, or, if you are using a 6-volt source Vin). Black wire is Vss (or Ground). White wire is signal -- plug it into an I/O pin of the BS2.
Sign In
Register
to comment.
