MAX233 question
I know, only vaguely related to BS/2s, but I figure folk here must have experience with MAX232 and MAX233 chips.
I'm trying to use a MAX233 (a 232 different pinout and the caps onboard) to bridge a stamp and a stereo component. For a simple test, I've tried just using the MAX as a loopback to a PC: I have the 5v output tied to the 5v input, and the RS-232 transmit and receive pins going from a PC to the chip. When I hit a character in hyperterminal, it should be immediately echoed back. But I get nothing.
Here's the pin layout. Am I missing something very obvious?
MAX pin 2 -> MAX pin 3 (send TTL output to input)
MAX pin 4 -> RS232 pin 3 (center bottom row, Tx)
MAX pin 5 -> RS232 pin 2 (Rx)
MAX pin 6 -> ground
MAX pin 7 -> +5v
MAX pin 9 -> ground
RS232 pin 5 -> ground
RS232 pin 7 -> RS232 pin 8 (standard stamp detect hack)
In Hyperterminal I've tried 2400 baud and·9600 baud, and Hardware and None for flow control.
I'm going mad - anyone have any suggestions? This wasn't supposed to be the hard part.
MAX pin 6 -> ground
MAX pin 7 -> +5v
MAX pin 9 -> ground
For a regular RS-232 DB9:
Connect pin 2 to pin 3.
Connect pin 1 to pin 4 to pin 6.
Connect pin 7 to pin 8.
Then, when you type anything in your terminal program is should be echoed back.
uhm....not sure what you mean by tying the 5V input to the 5V output...do you mean the ttl output goes to the ttl input?
You're pinouts look right....BUT, I'm terrible with anything 50/50.· So, I'm always getting TX and RX mixed up on my rs232 connector.· So, change them around.
The baud rate won't matter, since you're sending at the rate you're to receive.
Now you don't need the caps on the 233 but you do need to short pins 11&15 and 16&10 and 12&17 and 6&9. (it's all in the datasheet)
I'd first try swapping my Rx and Tx!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
Pin 12 to Pin 17.
Pin 11 to Pin 15.
Pin 10 to Pin 16.
These are pin numbers for the DIP package.
Anyway, it works now, thanks everyone. Bizarre, Arcane Home Automation is now within my grasp. Bwah haha ha ha ha...
