RS232 connection problems
I am interfacing an Oregon Scientific weather station (WRM918) to the BS2 to remote control an observatory with 2 telescopes for public use.· the problem is that Oregon Sci. does not publish and refuse to release the RS232 documentation.· So I don't know the settings nor how the data is transferred.· I know that it is unidirectional (sensors to base) and that it sends 12 bytes once every 3 senconds (approximately).
I hooked it up to Hyp. Terminal and tried all the different settings and can see the characters coming in but in weird symbols!
Any ideas of how to decipher this and try to use it in the BS2?
Al Najjar
Al Najjar
Do a google for serial port sniffer or monitor.· There's some trial software out there that should help you out!
Also, you could bring in the data to the stamp in one big string...just to see what it might look like!
Here's a snip of some code I used to see what the string was in a device.
My gear was talking at 19200 soo....you'll have to play with that much!
Basically what it does is, looks at the first 20 characters coming in and drops each one in a slot in an array.· I use the debug command to read back in the info for me.
n19k2· CON 110
serstring VAR Byte(20)
temp VAR Byte
temp = 0
serstring = 0
main:
· DEBUG CLS
· SERIN commin, n19k2, [noparse][[/noparse]STR serstring\20]··· 'input string
· DEBUG DEC2 temp + 1," :",HEX serstring(0),CR
· GOSUB display
END
display:
· DO
····· temp = temp + 1
····· DEBUG DEC2 temp+1," :",HEX serstring(temp),CR
····· IF (temp = 20) THEN
······· RETURN
······ ENDIF
· LOOP
RETURN
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
