STAMP Run toy
Hello smart people, my boss has come to me with yet another idea: She came in with two blocks· that have half of a picture on each of the six sides of the cubes. When you line up the correct parts of the picture, the cubes make a sound.( You line up the two parts of a car, and it makes a car sound) The way these were manufactured is fairly simple. They have rivets on the outside of he cubes, and when you are holding the blocks correctly, the rivets touch, complete the circuit, and trigger the sound. It's pretty cool, but all those rivets look pretty frumpy. I was thinking the same effect could be accomplised using magnets and reed switches, hidden beneath the surface of the blocks. However, I happen to know a certain STAMP that is pretty sensitive to EMI! How far do you think the magnets should be from the STAMP to ebb interferance/ destruction? I'm open to any ideas on how to make this work. It seems like a fun project.
I'm curious because I have seen no specs with regard to Stamps and EMI. Are there specs somewhere? Have you had some EMI related issues? I would expect (just from my own experience) that the Stamp would be pretty safe in the company of magnets that were simply asked to trigger a reed switch. Massive magnetic fields won't be necessary.
This does seem like a fun project.
Bruce
Work:· Clemensb@otc.edu
Good Stuff on my Blog: http://theDeadBug.journalspace.com
Jon Williams
Dallas, TX· USA
Why not go with opto's!!· You could put little LEDs in the cubes that are part of the image (LEDs for eyes) and when that part comes together with it's "mate" then those LEDs would trigger a photocell on the otherside.
To avoid false triggers on the photocell from ambient light.· Have a photocell on each panel that doesn't mate with an LED and that would indicate whether it was being covered (by it's mate's side) or open to ambient!
This might require two stamps or at least 2 battery's (as you have LEDs in both cubes that need to be powered)....so you might look at "light-pipes".
Basically you'd line an LED up to one end of a light pipe on it's Mates surface.· That lightpipe goes in to the cube and curves to come out another spot on it's surface.· In line with that end of the pipe would be a photocell.· So, you could have all the 'powered' items in one cube and just light pipes in the other!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
just a neat Idea I thought!!
Steve
Post Edited (Paul Baker) : 3/9/2005 8:37:03 PM GMT
either pot the inside with spongie material or the outside....or both!
Steve
They are about the best for light loads. (That's low current loads, not loads that generate light).
You can get AA's and 9Volts at most department stores (wal-mart ect.).
They advertise these as lasting 10 years in smoke detectors...
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
