SX28 Temp at 50mhz
Is it normal for the SX28 running on the Tech board at 50mhz to be hot --- hot enough to burn your finger if you leave it on it?
This seems too hot for normal operation.· Will an extremely tight loop cause this problem?
I also noticed that the voltage regulator gets super hot as well.
I haven't had any malfunctions with it, and it appears to be running programs just fine.· At lower clock rates, I don't think this is an issue.....
Thanks.
Keith M
Thanks.
Keith M
Post Edited (Paul Baker) : 3/9/2005 5:57:25 AM GMT
Even running at 50 MHz for hours......
Also, an extreemly tight loop as you say will not make the chip run warm, per se. As I understand it, the heat that is generated comes from a 'gate' making the transition from low to high or visa versa. Basically, next to no power is generated in the switching transistors when they are ON, or OFF. But during the transition from ON to OFF or visa versa, power is consumed. Running at 50 MHz, something inside the SX is making many many transitions....and those transistions = heat.
I·can say that the SX will get quite hot if an output pin is made·high, and shorted to ground, I've done it (on accident of course).
One amazing thing is that the output pin survived, that is, it after removing the short that pin still works. Don't know if it is about to fail the next second, however, but so far so good.
The SX also can run warm if pins are made inputs and left floating, but I have never had one get hot, from this activity. Nor do I allow unused inputs to float now that I am 'educated' in that area.
Post Edited (KenM) : 3/9/2005 6:16:44 AM GMT
I think I improperly connected something to ground.· A few minutes after I posted this, I prompted found a miswired connection, and went to bed.· This has happened in the past, and I wasn't really able to narrow down the cause.· I'm working on a new project and am constantly disconnecting and reconnecting pins -- and so I'm sure I'm going to make some mistakes.
Is heat generally caused by either something going to ground that shouldn't be, or something that should be going to ground that isnt?· I've had other heat problems in small circuits I've built --- and they are normally related to miswiring a prototype, but maybe there is a rule of thumb here.· When I build something, I'm constantly touching the IC(I do know about·ESD·issues)·to check for heat.· This is usually a good indication something has gone wrong.
As far as source/sink goes I have port B hooked up to a 6ft cable going to a PC's parallel port.· I would imagine this wouldn't be an issue, but I'm a beginner in all of this.
Thanks.
Keith
