keeping guard on battery voltage during discharge
Hello. I'm building a circuit in which a battery must not go below 2.5v while operating. The nominal voltage for the battery is about 7.4v. If I wanted to keep watch of the battery level, would it be a mere case of just adding a second wire to each terminal on the battery, and having the wires lead to an ADC?
Matthew
Matthew
Heres another since it is simple, use a micropower voltage reference of 2.5V feed it into the reference input of an analog comparator and the battery into the second input, problem with this is it would likely require another power source because it may act weird when trying to analyse a voltage that is the same as the supply voltage, but an ADC solution would also have the same potential problem.
Post Edited (Paul Baker) : 3/9/2005 5:50:38 AM GMT
Or is the 7.4 volt battery the only voltage source?
If there is a second voltage source, what is the voltage, and can the ground for the two voltage sources be tied together?
The 7.4v battery is connected to an ESC (electronic speed controller). In fact, three sets of wire are coming out of the ESC, one goes to the BASIC STAMP to read pulses, one goes to the 7.4v battery, and the other goes to the motor. The motor will draw around 30 amps most of the time.
So no, there's only one power source powering the motor. But there are a total of two sources (the other being a 9v battery for the microcontroller) in the entire setup.
I'm not sure if I answered your question though...
Matthew
When the voltage from the battery drops less than 2.5* volts the output to the stamp will be at 5 volts. When the battery is greater than 2.5 volts, the output to the stamp will be 0 volts.
*Depending on the resistor tolerance and the actual value of the stamp 5 volts supply, the trip point might be 2.6 v 2.55 v, etc.
You also may consider putting an optional 220 ohm resistor to protect the stamp in case you mistakenly make the stamp an output high, with the comparitor low.
Post Edited (KenM) : 3/9/2005 7:22:22 AM GMT
The 1381 is a simple 3-terminal device that gives a logic level on a pin when the voltage it is monitoring drops below a given threshold.
http://rocky.digikey.com/WebLib/Panasonic/Web%20data/MN1380%20Series.pdf
You will want a 1381-J I think. It has a 2.6 volt threshold. 1381-G is 2.4 volts.
Work:· Clemensb@otc.edu
Good Stuff on my Blog: http://theDeadBug.journalspace.com
Dead bug, I'm pretty sure that they dont check to see if the voltage is below a certain level, but rather in a predefined threshold.
Didn't know a device such as that existed. Certainly less to connect being a 3 terminal device.
I'm making some assumptions here.
If I understand your application, you are trying to monitor the voltage of a Li-poly (2 cell = 7.4V nominal) pack going to ESC and you don't want the pack to go below 2.5 volts.· Is this correct?
IF so, then you really don't want the pack to go below 5.0 volts (2.5 volts per cell).· Taking a two cell pack down to 2.5 volts (total) will kill it.· Some people suggest stopping the drain at 3.0 volts per cell.
I am looking at doing the same thing with my setup.
- Bob -
