SolidState Relay Isolation
I want to use the following SSR for actuation of·solinoid, power supply for Solinoid is 2.5a 25vdc.
BS2 side is; straight off pins to relays then vss do I need anything else (ya know I want to protect my bs2p24)
Solinoid side will be completly seperate including ground
http://www.clare.com/home/pdfs.nsf/www/Laa110.pdf/$file/Laa110.pdf
DTQ
Jon Williams
Dallas, TX· USA
The following circuit should easily handle the job.
Good guy prices for the IRL520 can be had at www.glitchbuster.com
I am not affiliated with glitchbuster in any way, put·push this guy because:
Jon Williams
Dallas, TX· USA
