Srf08
hi,
my range sensor was working fine and now it is showing me everything zero,-- zero range and zero light
once I try to change the address it also does not --- but once I switch on its led blinks twice -- IS it bad sensor or some thing else wron-- any one having any idea-- please help
Thankyou
Thankyou
Infact I am using HP DC power supply-- it was working fine -- and meanwhile I was working on other part of the robot and other sensor and it was only hooked in -- no program runing it---but now once I tried to test it suddenly it stopped giving any signal.
Do you have any idea?
Thankyou
Post Edited (Robert Schwartz) : 3/9/2005 9:10:47 PM GMT
I can read voltages at SDA and SCL not 5V exactly but like 4.4V and even if I increase the input voltage it stays same on these pins-- what do you say
Thankyou
As for power, the srf08 is known to be power hungry when pulsing out. One suggestion I found on the forum was to add a large capacitor between the negative and positive terminals to absorb some of the drain... might help.
Also make sure the "new addition" to your circuit isnt causing the problem. Work piece by piece.
Post Edited (Jonb) : 3/9/2005 6:59:51 PM GMT
Power on.................................275mA..... 3uS
+/- 10v generator Stabilization..25mA...... 600uS
8 cycles of 40kHz "ping"...........40mA...... 200uS
Ranging..................................11mA...... 65mS max
Standby..................................3mA........indefinite
Jon Williams
Dallas, TX· USA
