How to monitor voltage ?
I'm still a novice !!
I would like to know how to monitor voltage such as 1-100 vdc both in terms of hardware and code. Thank you.(I did search the forums first but, couldn't find it)
An A/D converter would be one thing that might work...but you'd have to scale it down.· And with 100Vdc I'd look to some isolation (optoisolators)!
You could use either a simple voltage divider for the scaling or an op-amp.· This is where the experimenting comes in to it...which might work better.
As far as the code goes....look up some of the Nutz&Voltz articles off the Parallax webpage (downloads section I believe).· There is an article in there about someone using a photocell and an LED across a battery terminal to determine the voltage on the battery.
I attached the PDF of the article (I think it's the right one)....
Read thru the "What's A Microcontroller" text too!· It's a free download from the parallax site.· Good beginner material in there!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
