Two Stamps
Hi everyone.. I seem to have run out of space on my BS2p40 and then I read this NUTS AND VOLTS column where you could integrate two stamps. The slave program mentioned in the column only displays time in hours[noparse]:mins:[/noparse] secs using the ds1302 but no date. Is there a way to implement it to display the date which the user can chag=nge using the master basic stamp. I am attching the codes for the master and slave which is also available on the parallax website.
Here is the column: http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv81.pdf
You've used up all 8 banks of 2K/bank of programming space? If so, that's one huge program. Presuming that you haven't used up all the programming space in all 8 program slots, you may want to take a look at Nuts & Volts Colum 87 available from here:
http://www.parallax.com/html_pages/downloads/nvcolumns/Nuts_Volts_Downloads_V3.asp
Bruce Bates
In one sentence - they aren't. They run concurrently or serially; one then the other. Another way to view it is to envision parts of your program as subroutines, and those subroutines cleverly exist in another part of memory. Here is another reference which may shed some additional light on this whole idea:
http://www.emesystems.com/BS2SX.htm
Thanks to Tracy Allen for his excellent applications snotes.
Bruce Bates
Two or more (up to eight) program banks are available for your use, each of which can contain a separate and distinct set of programming instructions. The last link I offered will even show you how you can communicate between program banks if that is a requirement.
Indeed, the $STAMP directive indicates which program is assigned to which program bank, and yes they are separate .BSX, or .BSP files, as appropriate. They needn't be dowloaded "one at a time" as you put it, since they can all coexsist within the Stamp Editor at the same time. However, they CAN be downloaded or manipulated by the Stamp Editor separately. I hope that's not confusing. It's only intended to show that the Stamp Editor is quite flexible in this regard, and that the $STAMP directive is the key to it all.
Bruce Bates
When using two different Stamp modules connected with a serial link the programs are in fact running at the same time. That's what's going on in the column referenced.
When using one of the multi-bank Stamp modules (BS2e, BS2sx, BS2p, BS2pe) you can have multiple programs on the same module (each program lives in its own memory bank) but ONLY ONE program runs at any given time.
Jon Williams
Dallas, TX· USA
