Hey what hardware do i need to communicate between my laptop and a robot. Even anything needed to convert the stamp only transceiver, could use the help thanks?
Take a look at the MAX232, it allows bidirectional Serial communications. If you want a wireless approach there are a few RF modules that work to 1000ft.
For wireless here are a few popular approaches, as you shop keep this in mind. For 1 way comms get a transmitter and receiver, for 2 way comms get 2 tranceivers. Also, you can use pin 16(programming pin)·on your stamp board for data acq., however it is a good idea to build a simple interface with a max232 and use one of the regular stamp i/o pins.
Post Edited (Jonb) : 3/2/2005 9:50:51 PM GMT
1. Parallax's line of rf solutions, I have used them all and they work fantastic!
http://www.parallax.com/html_pages/products/communication/rf_modules.asp
2. Ewave stamper, $350 for 2 trancievers but works like a charm and BUILT FOR THE STAMP
http://www.electrowave.com/products/stamper.shtml
3. Many simple serial rf solutions here and inexpensive
http://www.rentron.com/PicBasic/RemoteControl.htm
4.·A newer product
http://www.eazix.com/products/zigbee/ez-zbm.htm
5. A cheap trans/rec set for ynder $40·but requires an encoder
http://www.e-clec-tech.com/tlprlpset.html
Hope it helps!
