SERIN hell no, it won't go
I would like to send 3 or 4 values to my stamp (bs2)
sendings is not the problem, receiving is the problem
send in vb (
value1=x······· ( ASCII)
value2=190···· (0-200)
value3=195···· (0-200)
value4=116···· (0-200)
total_value as string· = value1 & value2 & ......
) ok
Main:
· SERIN 16,$4054,PAUSEit,500,PAUSEit,[noparse][[/noparse]DEC3 val2,DEC3 val3,DEC3 val4]
·· DEBUG Val2,Val3,Val4,":"
··· PAUSE 20
GoTo Main··
Main:
· SERIN 16,$4054,PAUSEit,500,PAUSEit,[noparse][[/noparse]STR mVal\7,DEC3 val3]
·· DEBUG mVal(0),mVal(1),mVal(2),mVal(3),mVal(4),mVal(5),DEC val3":"
·····(OK !·
·GOOD
· GOOD )
········ val1 = (mVal(0) mVal(1) mVal(2))
········ val2 = (mVal(3) mVal(4) mVal(5))
··· DEBUG· val1,",",val2,",",val3,":" (
·hell no)
··· PAUSE 20
GoTo Main
send in vb (
) ok
Main:
··· PAUSE 20
GoTo Main··
Main:
·····(OK !·
·GOOD
· GOOD )········ val1 = (mVal(0) mVal(1) mVal(2))
·hell no)··· PAUSE 20
GoTo Main
Steve
http://members.rogers.com/steve.brady
SERIN 16, $4054, [noparse][[/noparse]Val1, Val2, Val3, Val4]
THEN, you can see them as:
SEROUT 16, $4054, [noparse][[/noparse]Val1, DEC Val2, DEC Val3, DEC Val4]
Where 'Val1' would be the "x" character, and the others would be converted into
their decimal equivalents -- Byte '190' becomes 3 string bytes "190".
This assumes you ARE sending them as bytes from your PC originally.
The "SERIN xxx,yyy,[noparse][[/noparse]DEC MyVal] reads a 'string' with a CR after it, converts it
to a decimal number, and puts the decimal number into MyVal.
You had the right idea, just the wrong order of implementation.
Oh, and what did you intend by "val1 = (x y z)"?· You've left out your operators, there.
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv89.pdf
Jon Williams
Dallas, TX· USA
