Problem with transfert to FT245A FTDI
Hello,
·I am a problem in my SX/B program.
I am write the same in assembly langage, and it walk.
I am write a page in french for the SX.
You can see my work at :
http://perso.wanadoo.fr/asnora/sx/sx.htm
Excuse me for my longer code, but·I am begginer in SX/B basic.
This routine, don't walk at read_USB
The led refuse to light.
'·· File...... Test_USB.SXB
'·· Purpose... USB transmission
'·· Author.... Jean Brunet
'·· E-mail.... jean.brunet17@wanadoo.fr
'·· Started...
'·· Updated... 28/02/2005
' Program Description
' Communication with FT245AM FTDI chip
' read and write a byte, write a string on USB port
DEVICE········· SX28, OSCHS2, TURBO, STACKX, OPTIONX
FREQ··········· 50_000000
' IO Pins
RXF·VAR·ra.0· ' in
TXE·VAR·ra.1· ' in
WR·VAR·ra.2· ' out
RDe·VAR·ra.3· ' out
led·VAR·rc.0· ' out
PUSB·VAR·rb·'in/out
' Constants
' Variables
dt·VAR·Byte
reg·VAR·Bit
idx·VAR·Byte
string·VAR·Byte
Msg·VAR·Byte
rtnAddr·VAR·Byte
· PROGRAM Start
Msge:
·DATA··· "A",13,0·'0
·DATA··· "B",13,0·'3
·DATA·· "ABC",13,0·'6
Start:
· TRIS_A = %0011
· TRIS_B = %11111111····'
· TRIS_C = %00000000
· Low led
' Program Code
main:
··GOSUB·read_USB,dt
··IF·reg=0 THEN main
··dt=dt & %00000011
··BRANCH dt, null, yes, no, three
null:
··GOTO· main
yes:
··GOSUB·write_string,0
··HIGH·Led
··GOTO·main
no:
··GOSUB·write_string,3
··LOW·Led
··GOTO·main
three:
··GOSUB·write_string,6
··GOTO·main
' Subroutines
' write a string on port B
write_string:
·idx = __PARAM1
loop:·········································
· ·READ Msge + idx, string················
· ·INC idx
· ·IF string = 0 THEN Fine
· ·GOSUB ·write_USB,string
·GOTO·loop
Fine:
·RETURN·
' read a byte on port B
read_USB:
·rtnAddr=__PARAM1
·reg=0
·IF RXF = 1 Then Fin
·LOW·RDe
·PAUSEUS 1
·__RAM(rtnAddr) = PUSB
·HIGH·RDe
·reg=1
Fin:
·RETURN
' write a byte on port B
write_USB:
··dt=__PARAM1
Att:
··IF TXE = 1 Then Att
··TRIS_B = %00000000
··PAUSEUS·1
··PUSB = dt
··PAUSEUS 1
··HIGH·WR
··PAUSEUS 2
··LOW·WR
··TRIS_B = %11111111
··RETURN
end
Thank you for your "patience"
Jean
'·· Started...
' IO Pins
RXF·VAR·ra.0· ' in
TXE·VAR·ra.1· ' in
WR·VAR·ra.2· ' out
RDe·VAR·ra.3· ' out
led·VAR·rc.0· ' out
PUSB·VAR·rb·'in/out
' Constants
' Variables
dt·VAR·Byte
reg·VAR·Bit
idx·VAR·Byte
string·VAR·Byte
Msg·VAR·Byte
rtnAddr·VAR·Byte
· PROGRAM Start
Msge:
Start:
· TRIS_A = %0011
· Low led
' Program Code
main:
··GOSUB·read_USB,dt
··dt=dt & %00000011
null:
··GOTO· main
yes:
··HIGH·Led
··GOTO·main
no:
··LOW·Led
··GOTO·main
three:
··GOTO·main
' Subroutines
write_string:
·idx = __PARAM1
· ·INC idx
·GOTO·loop
Fine:
·RETURN·
read_USB:
·rtnAddr=__PARAM1
·reg=0
·LOW·RDe
·PAUSEUS 1
·HIGH·RDe
·reg=1
Fin:
·RETURN
write_USB:
··dt=__PARAM1
Att:
··PAUSEUS·1
··PUSB = dt
··PAUSEUS 1
··HIGH·WR
··PAUSEUS 2
··LOW·WR
··RETURN
end
Jean
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
Now, my led put ON and OFF.
I research if a member who have experience of the RAVAR module with XP.
My transmission PC -> RAVAR is correct.
The RAVAR -> PC tell me the number of the write string, but not the possibility to read the string.
I am also an I/O error on the PC.
The RAVAR module is USB 1.1 and my PC is USB 2.0. Compatibility is done ?
Jean
Maybe someone else can help with that ?
Bean.
www.sxvm.com
