You're just switching a current?· Check out the transistors section of Glitchbuster (http://glitchbuster.com/#xstrs).· I'm using the IRL520N MOSFET to switch 1.5 amps, but it can handle up to 10A.· Depending on your demands you might need a heatsink.
I use the IRL520N to switch current to a nichrome wire.· It's a weather balloon cutdown to jettison the balloon remains once it bursts.· With 1.5 amps the MOSFET doesn't even get hot, but I'm only using it·for the 10-15 seconds.· And the gate is logic level; you can hook it right up to a Stamp I/O pin.· The only other component I have on it is a 47K pulldown resistor, to keep it switched off when there's no input at the gate.
If you're only switching on for a few seconds you can get away with the IRL520N without a heatsink.· Actually, any TO-220 case device is going to be able to handle the load.· The 2N3055 is a TO-3 case, which is a bit bigger, but it will still do the job.· The small plastic TO-92 case devices are only good for a couple hundred milliamps.· And the small metal can TO-18 devices are good up to about 800mA.
There's nothing to know about the IRL520.· Gate goes to the Stamp or PIC I/O pin, Drain to the current source that you want to control, and Source to ground.· And to keep the Gate from floating use a pulldown resistor, about 47K will do.
Just out of curiosity, where are you getting a 9V supply of 2A? ....Sounds odd
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
Beau, I'm getting the power from a Panasonic 9v N-6PT.
Johnny
Matthew
k
