Shouldn't be a problem if you have a Terminal Emulator on the PDA and a null-modem adapter on the cable as the cable that comes with PDA's is meant ot connect to a PC, not a Basic Stamp.
(Assumes it comes with a serial synch-cable.)
I believe the DEBUG command transfers data in 9600/8bit?
