I use BS2 to rotate continuous motor from parallax. I can make it rotate continuous 360 but I can't make it return to its starting point. It look like it loss track of its location. Is this suppose to happen?
Normal DC motors don't have any means of returning to their original start location. As Dave said, if you want to make it turn a revolution and return to it start location, you can either use a stepper motor, which turns a certain number of degrees each turn, or use an encoder, which has a number of holes with IR detectors that tell you how many degrees you have travelled.
There are couple of ways to solve this issue, one is to use an encoder and the other way is to use a stepper motor.· Here is a link for the encoder:· http://www.parallax.com/detail.asp?product_id=28107.·
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
If you have a hankering to do some reading, research open-loop vs. closed-loop systems...
XYZZY...PLUGH...*poof*
